Issue with Field App on Windows Machine
3007
11
01-10-2019 07:43 AM
GaryBowles1
I am trying to run the Survey123 Field App (3.1.158) on a windows 7 machine. When i open S123, nothing happens when i click on a survey on the My Surveys page. I can login to Portal, download surveys, click on the bars in the upper right corner, go into settings, etc. but when i try to open a survey i get nothing.
I have also tried installing and running the Classic Survey123 but get the same results.
--gary
JamesTedrick
Esri Esteemed Contributor
Thanks.  As I mentioned, the main errors I saw involved the database; there were another set that appeared to relate to the positioning of text.
This may sound like an odd test, but can you attempt to open a survey via a URL (from the collaborate tab) in the application?  That might help determine if this is a form issue or a user interface issue.
by Anonymous User
Not applicable
Hi Gary,
Also see the post I replied to here which could be a similar issue on Windows 7: https://community.esri.com/message/823911-re-version-survey-connect-3-dont-work?commentID=823911&et=...
Phil.
