We have created a survey form from a hosted feature service. In the survey, we are using the Inbox folder to load the current features. These represent previous year’s inspections and we would like to edit a copy of the survey to maintain certain information. It seems that the only way to create a copy of a survey is from the Send folder.
Having only one option to create copies of surveys from the Sent folder creates a difficult workflow. It seems you would need to open the survey from the Inbox, save the survey with no changes, and then send the survey from the Outbox. After that, you would create a copy from the Send folder, edit the survey and then send the edited copy. It would be an easier workflow to be able to create the copy directly from the Inbox, make the needed changes, and then send the updates.
