Is there a way to return a user submitted answer based on a selected choice?
1897
04-22-2024 08:09 AM
BaileyBellavance
I've been trying to make a survey question in Survey123 Connect where a user inputs their shipping address and then they can check a yes no question to say if their shipping address is the same as the billing address and then based on that answer, pre-populate the billing address questions based on the values of the shipping questions they answered above. I've been trying at this for a few days, but I'm starting to think it's not possible to even return a user submitted answer to another survey question at all, is it?
DougBrowning
MVP Esteemed Contributor
In the second set of fields you can do if(sameasquestion = yes, field1 value, '')  So it uses it or goes blank.
DougBrowning
BaileyBellavance
Awesome, that helped, thank you! The issue I'm having now is the user is having to click in the second field for the calculation to actually happen now, I set the calculation mode to always already but it's still needing me to click in the field.
DougBrowning
Try adding a relevant so it does not display and thus calc until they select yes.
BaileyBellavance
That was it, thank you so much for your help!
