I have a point feature with a related table of a 1 to many relationship. The point features are storm water outfalls and the table are inspections.
Survey A populates the point feature and allows the user to add supplemental information to the outfall. My plan is to use the inbox feature for the user to pick an existing outfall and add the associated information via survey123. I need to use survey123 for this, so I can filter multiple choice answers etc etc. I'm using functionality that isn't yet available in field maps (otherwise I would start there)
Survey B populates the inspection table. Typically my workflow for this would start in collector, the user would select the outfall they want to inspect, then they would select the custom URL in the popup to launch Survey123 and pass Outfall information to the inspection.
Since this is round one of collecting basic outfall info (Survey A) and they need to do an inspection (Survey
. It would be nice if they didn't have to switch back and forth between apps since they're going to end up back in Survey123 anyway.
ie. Survey 123 (Survey A) -> Back to Collector -> Survey123 (Survey
I know in the Survey123 website, you can see up a thank you screen and prompt the user to submit another survey. It would be great if at this point, I could add my custom URL to immeditaly launch Survey B and pass information without going back to Collector first.
Is this possible? Or is there something else that would function this way?
