Is there a way to get notified when a survey has been completed in the field
1530
04-03-2017 11:52 AM
deleted-user-IzSe5qeV-6po
When a field worker completes a survey and saves it is there a way that a notification (email or other method) can be made to the survey owner or a designated person so that possible action can be taken based upon the response?
Tags (1)
GaryBowles1
Mike,
We are using GeoEvent to poll the hosted feature service from a survey and whenever a new record is added to the fs, an email is sent out. You can set this up to send the email for a survey or for an answer to a specific question within the survey.
Are you using Survey123 Connect to create your surveys or survey123.arcgis.com?
--gary
yes
Sorry
Survey 123 connect
