Is there a way to disable the option of adding an image from the camera roll?
1118
01-07-2020 01:29 PM
RufaroKaseke
I am building a survey using Survey123 Connect. I want the end user to take a photo when they fill out the survey but I do not want them to have the option of adding an image from the camera roll. Is there a way to configure this?
I found a 2017 post that said to use the 'annotate' Appearance but that feature has since been updated to allow adding an image from the camera roll as well, so that's a no go.
Thanks!
Shwu-jingJeng
Hi Rufaro,
Currently there is no way to disable the image folder in the form. We do have an existing issue open for this enhancement rewquest you can track with: ENH-000116753
I encourage you to contact Esri Support. Our Support team will assign an official enhancement number for your records. Similar requests from other customers can then be attached to the same enhancement request, which helps us assess demand for the enhancement and prioritize it accordingly.
RufaroKaseke
Thank you, Shwu-jing Jeng‌.
