I am doing bird surveys made up of 6 stops along a route. Ideally we can make it to all 6 but conditions may only allow us to get to 4 or 5 etc. The entire survey is a route and each stop is a new repeat/"record" within my survey setup and there are required questions within those stop. So you cannot hit the next arrow to start a new stop unless you have completed required fields for the first stop. I'm testing it out now and if I try to submit a survey with only the first stop filled out it won't let me and says "Record 2: this is a required question". In my excel form on Survey123 Connect, I do not have that "begin repeat" row as a required question, just the actual fields within that repeat/record have required questions. I have put 6 in the repeat count column of that row because I do not want surveyors accidently creating more than 6 records per route. I suspect this is causing my problem. Is there a way to cap the repeats/records but also not make that cap number required to submit?
