Is there a way to base a relevant expression to show questions if one option is chosen?
1058
04-18-2019 10:12 AM
KaitlynAbrahamson
I would like to have a series of questions asked only if one of option of the previous question is chosen.  This is the example:
If the survey taker chooses to salvage a sign, they don't have to fill out the following questions about the sign.
If the survey taker chooses to replace, leave existing, or install a sign, the following questions about the sign appear to fill out.
Is this possible?
JamesTedrick
Esri Esteemed Contributor
Hi Kaitlyn,
Yes, this should be possible by either:
Web Designer: set a rule on the choice question
Survey123 Connect: setting the relevant columns of the questions that will be hidden/shown - see https://community.esri.com/groups/survey123/blog/2015/08/24/using-formulas-in-survey123
KaitlynAbrahamson
I wasn't clear enough.  I am trying to hide a series of questions if one option to a previous question is selected.  Make sense?
DougBrowning
MVP Esteemed Contributor
Stick them in a group and add a relevant to that group.
