Is there a recommended procedure to re-publish a survey as testing notes needed revisions?
651
03-15-2022 07:54 AM
by Anonymous User
Not applicable
Katie_Clark
Well, some updates to a survey won't have any negative effect on existing data. If you're doing updates that will affect existing data, Survey123 Connect will give you a warning before you publish. If you decide to proceed, it is recommended to download the data from the Feature Service as a FGDB before republishing.
Look at the "Update Surveys" section of this documentation for more info.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
by Anonymous User
Not applicable
Thank you Katherine
