Hi Everyone,
Since the issue is between Survey123 and Collector regarding the edited layer. Is there a way to take the Survey123 feature service and develop a new one based upon the original, yet the new one would not be deep linked to Survey123? I apologize for such a basic workflow, but I am now within "Crunch time"!
The culprit to this is an incorrect timeReference object set in the Feature Service created by Survey123 Connect. I have added this to the backlog in Survey123 Connect for resolution. The Collector team is also planning to handle this incorrect timeReference object better in the next update. Here is the workaround for now:
1- Login to ArcGIS.com and go to My Contents
2- Look for the Survey123 feature layer and open its details page
3- Scroll down to the Layers section and click on time Settings. Disable time and save
4- Create a brand new Web Map with this feature layer
5- Configure the popup to use Custom Attribute display with URL Scheme link to trigger Survey123 and passing appropriate attributes to Form
6- Share new Web Map consistently with the sharing of the Feature Layer
7- Open Web Map from either Collector or Explorer for ArcGIS, tap on feature popup and launch Survey123
Note: If you would like to keep time settings, you can also after step 3 go back and enable time in the layer. After disabling, saving and enabling, you will get a correct time enabled feature service.
In ArcGIS Online, you can create a new, empty feature service from an existing one - Publish hosted feature layers—ArcGIS Online Help | ArcGIS
Alternatively, you could download the file geodatabase, unzip and delete all rows and rezip (these parts optional), and then add the file geodatabase and use the option to republish.
James Tedrick will the first option allow for the new feature service to be updated when the old one receives pushes from the form related to Survey123? I am dealing with the iOS 10 bug and having all of our fire apparatus having iPads.
Any word on when this bug will be fixed?
Hi. On a closer look into this issue, it seems like the problem may be specific to Oscar's survey. The Collector team is looking into why the feature service is making Collector crash.
Thank you Ismael, it works perfectly!
