Is it possible to use an if then statement to populate the answer to another question?
2680
10-26-2016 12:37 PM
HeathAnderson
I have a series of questions about the exterior of a house such as: roof, gutters, siding, chimney, foundation, etc.  Each question can pick from a list (select_one), 1 (Intact), 2 (Replace), 3 (Remove).  Can I create a select_all_as question so that if they choose 1 from the list as “Intact” it will populate all the remaining questions, roof, gutters, siding, chimney, foundation, etc. as 1?
JamesTedrick
Esri Esteemed Contributor
Hi Heath,
Currently we don't support calculating values on a select_one question.  For what you're trying to accomplish, I think there is another way that might work.  There is a function called coalesce that allows you to get 'the first non-empty value in a set of questions'.  This can be used in combination with relevancy to hide/show all or the individual responses and then get the response for use in another field.  See the attached XLSForm.
JamesTedrick
Hi Heath,
Fisher_Austin
Is there a source for more details on the "coalesce" and other similar functions?
