Is it possible to target multiple related tables of an existing service?
1808
02-20-2024 11:14 PM
ChristopherCounsell
MVP Frequent Contributor
I publish a survey as:
  • Geopoint
    • Table 1 (repeat)
    • Table 2 (repeat)
I then publish a second survey targeting the existing service with the intention of using a custom url to pass the point globalid and add records to the tables. I want to populate both Table 1 and Table 2 in the one survey.
  • Table 1
  • Table 2 (currently a repeat in the form, to recognize as second table)
This works well for one table, but having two tables gives issues like:
  • two 'parentglobalid' fields needing to be present/populated from the custom url parameter
  • Error 'Destination relationship not found for table'
  • Error 'parent layer not found for table'
These seem reasonable with how repeats are used within survey design.
I believe I can bypass these issues by having table 2 be nested when first publishing and creating the hosted feature layer. But then I believe Table 2 won't have a direct relationship to the geopoint layer, but to Table 1? This is an issue later as we want a globalid-parentglobalid relationship between the Table 2 and the Layer for other surveys and mapping. I could add a custom guid field to store the layer globalid in Table 2 so it ends up like this:
  • Layer (globalid)
    • Table1 (globalid, parentglobalid)
    • Table2 (globalid, parentglobalid [Table1], customguid [Layer]
Is it possible to submit against both tables but maintain the global/parentglobalid between the layer and table 2?
If not, is it possible to create an additional relationship class between the Table2 customguid and Layer globalid? Any comments on the +/- of doing so?
Otherwise does anyone have any good insight, suggestions or resources on working with relationships/guids with multiple repeats and targeting existing services?
2 Solutions
ZacharySutherby
Hello @ChristopherCounsell
Based on
  • Geopoint
    • Table 1 (repeat)
    • Table 2 (repeat)
There's no relationship between Table 1 and Table 2, to support a survey that points to Table 1 and includes Table 2 as a repeat the parent survey needs to be:
  • Geopoint
    • Table 1 (repeat)
      • Table 2 (nested repeat)
Thank you,
Zach
ChristopherCounsell
Thanks @ZacharySutherby . I'd hoped for a world where I could keep the globalid/parentglobalid relationship consistent between the two tables and the geopoint layer.
I ended up manually creating the relationship between a custom guid field in table 2 and the point layer globalid field. Also had to recreate the other relationship classes as exporting from ArcGIS Online to Pro and republishing had a bug where the forward/backward labels were dropped so the relationship was called ''.
While I'm glad there's a functional relationship to use between the point layer and table 2, I'm also hoping there are no more issues after having taken the above workflow...
ZacharySutherby
Based on
  • Geopoint
    • Table 1 (repeat)
    • Table 2 (repeat)
  • Geopoint
    • Table 1 (repeat)
Thank you,
Zach
ChristopherCounsell
