Is it possible to load an embedded survey123 in Operations Dashboard, only after a list item has been selected?
750
05-12-2020 11:10 AM
DavidBondy1
When I load the Operations Dashboard, it seems to execute the action for a list by sending the first record over automatically. Is there any way to disable this so the form only loads, after the end user has selected a list item?
BrettStokes
Hi David,
Were you able to find a way to achieve this? If so, please share on the forum.
Brett
DavidBondy1
No, unfortunately I wasn't. i just used a workaround so that a filter applied a default value that resulted in no data. So the list only populates once a dropdown option is selected. Not an ideal solution but it's the only one i came up with.
