Hello James/Elias,
I'm having partial success using the WeatherData.js Example from the Early Adopters - Survey123 -custom JavaScript functions. I was able to get a simple example to work just fine and it's uses the geopoint to submit an xmlhttp request to the openweather.org api and returns JSON.. Once I tried moving the sample into my production survey, no love was found...
I've updated my XLSform version, followed the sample setup and therefore the same javascript file stored in the 'extensions' folder, but the weather data fields won't populate outside of Survey123 Connect (win10). I've re-published a fresh Survey but still no luck; using the latest versions of Connect, Fieldapp, etc. Testing on iOS, windows10 and android without consistency.
So, is it safe to say, it's just too early for this feature or would anyone have any suggestions?
thanks all,
brian
