Is it possible to attach a photo to a record in Survey123?
3402
09-01-2015 11:41 AM
SaraGottlieb
I'm trying to compare functionality of Survey123 with ArcGIS Collector.  Collector allows a user to attach a photo to a record.  Does Survey123 have that functionality?
Tags (1)
RonKnepper
Occasional Contributor II
Yes, there are good and bad of each from what I found.  It would be nice to combine the 2.  Survey lets you add a photo (video/audio seem to be in the works) but only a single photo per record (though thinking about this now you might be able to create 2 fields for photos and I am going to try that!).  I like that you could build in logic to Survey 123 and use it as error handling of sorts.  Collector still can do more in terms of schema setups and I think its easier but that's also because you do not have the logic portion.  I also have not played much with getting the data out of Survey 123 but I am sure there are similar ways.  Collector is also nicer in terms of overall display and setup for the end user IMO.
IsmaelChivite
Esri Notable Contributor
Hi. This  Multiple Photos in Survey123 discussion expands a bit on the details of photos in Survey123.
