Invalid Shape Extents when editing in Inbox
4010
12
08-03-2017 12:11 PM
SarahButler
I have a survey that worked perfectly last week.  I published a web layer from ArcGIS Pro to ArcGIS Online.  I created a survey in Survey123 with the Inbox mode enabled.  In Survey123, I was able to load my data into the inbox.  But now when I try to edit it and load the existing data I get the error Code 1000 Invalid column name 'Shape__Extents'.
Any ideas of why this started happening and how to fix it?  I do not have any columns called Shape__Extents in my data, so this must be something Survey123 is creating?
JamesTedrick
Esri Esteemed Contributor
either attach it using the 'advanced editor' capability in GeoNet or e-mail me - jtedrick AT Esri.com
CharlesBailey3
Sorry to divert but I have a very similar error except there are multiple fields listed in the error message i.e. Shape_1, Shape_3, Shape_5 and so on up to 9. None of these fields exist in the feature service. What do you think James? Thanks, cob
JamesTedrick
Hi Charles,
This sounds fairly unusual - it would probably be best solved by filling a ticket with Esri Support.
