I had a nice workflow running for a week or more. However, it started failing yesterday. I replicated the scenario as a new test, however, that only worked once and now it too is failing.
The error I'm getting in both Scenarios is when it tried to Create feature report. The error shows:
I've tried to update the parameters and re-selected the ObjectID, but it continues to fail at that step. Is anyone else having this problem?
Update - I can get it to pass that module by using the globalID instead of the objectID (perhaps due to deleting previous test records and objectIDs being repeated?). However, now it is hanging up on the HTTP module with a similar message:
Hi Ben,
It appears that you need to double-check the HTTP module - make sure it's reading the url of the file from the custom report step.
