Integer field is truncated when the survey is saved then edited
4716
15
02-05-2019 03:44 AM
GrahamStobie1
Hi
I have an integer field in a survey that is used to store an 8-digit 'ID' field - e.g. 12345678. However if the user collects some values including the ID, closes the survey without sending, then re-opens it to edit/complete the survey, commas are added to the ID, the value is truncated, and the value shows as invalid - i.e. the ID above would be now show as 12,345,67 and would be in red text. (see attached).
I understand that this is because of the 9-character integer field limitation, but as far as I can tell this is new behaviour (or the survey team have changed their workflow...). Is there a way to stop this happening? We have already collected >1000 surveys using this form so I want to avoid changing the ID field to text if possible.
by Anonymous User
Not applicable
Hi Adam,
I had a look at the log file and can not see anything too obvious to explain why Connect crashes. Can you share your xlsx file and any csv files in media folder? I would like to try and reproduce the issue on my machine and have a more in depth look at your survey and the expressions you are using.
Phil.
AdamDaily
Philip, I found the error in here, please disregard. I've got it working now. Thank you.
AdamDaily
How do you account for variation in attribute length? So a mask of "9999" works for a 4 digit number, but if the values in this field vary up to say 6 digits, this will not work for a 5 or 6 digit number. That goes the other way as well, so a "999999" mask will work for a 6 digit number, but will not work when entering only a 4 digit number. What is the correct format for different length values into an integer field when having to use inputMask?
JamesTedrick
Esri Esteemed Contributor
Hi Adam,
The Input Mask specification supports defining a permitted but not required character - in the case of numbers, use a '0' instead of a '9'.
AdamDaily
James,
The masking does not seem to function as indicated by the table. "0" reacts the same way "9" does, only permitting a specific number of input characters, "0000" for exactly/only a 4 digit number. "0" is also stored as a text value if more than one is used. Converting "0000" to number changes it back to a single "0", which does not work.
I tried "n" and "x" and "#" as well with the same results (only works when the number matches exactly the number of input characters. Example: value "8200",  inputMask "9999","nnnn", or "xxxxx" work (add 1 "x" for the comma). If my formula is shorter than "nnn" for "8200", the last 0 gets cut off. If it is longer, "99999", the program returns "Invalid Integer" error.
JamesTedrick
Hi Adam,
In the Excel sheet, remember to specify that this a text string of 0's - the easiest way to do that is to prepend the string with an apostrophe (i.e., '000000 ) - this works for me to submit a 4 digit text string
