Inserting % symbol in Survey123 Connect
1800
03-10-2020 11:05 AM
SMa
How do you insert a % symbol as part of the value within an integer field in Survey123 Connect?  For example, I enter 1 as my answer and automatically the percent symbol populates after 1.
BenTurrell
Hey Sherry Mattice‌,
I don't think you can add a percentage sign to the field as its of type integer. You have two options, you can add it in when you display it using Arcade or you can use a text field and a regular expression to capture it in the survey.
I've attached an example survey that will capture the number and percentage sign in a text field. If you need to do calculations on the field then you are better off leaving it as an integer field and using an Arcade expression to add a percentage sign to the end.
Thanks
Ben
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
