Indicating Photos in the Sent/Inbox
951
02-25-2020 06:50 PM
DrewThompson
Objective:
To Effectively Indicate which Line Items (Surveys) Photos are Taken in, from the Sent/Inbox.
Case/Function:
We average 300-1500 line items for some of our larger surveys and we are already utilizing the "Save Favorite Answer" function as well as the "Copy the sent data to a new survey" function. However, it is still difficult to scroll through large quantities of similar data without an image reference.
We have added a yes/no question to the top of the survey that currently displays "PHOTOS" in the Sent/Inbox. However, it requires the surveyor to remember to select "no" when they copy the line item. This leaves room for error and becomes useless to them if they forget.
Questions:
  1. Is there a way to add an icon image (of one of the photos taken within the survey) to the line items that have photos in them in the Sent/Inbox?
  2. If not, is there a way to highlight the line items that contain photos?
  3. If not the previous two, is there any other way to indicate which line items contain photos?
JamesTedrick
Esri Esteemed Contributor
Hi Drew,
By 'line items', are you referring to the instance_name that is displayed in the submission lists?  The instance name is not able to display a thumbnail of an image; it can display the filename.  You can also use calculations to indicate if a photo is present using a calculation like (to report if a question names photo has a photo:
if(string-length(${photo}) > 0, "Photo present", "No photo")
DrewThompson
James, that solution should work!
Thanks very much!
DrewThompson
Hi James, I just tried that solution. However, it isn't working when we copy the sent data to a new survey. It's continuing to calculate that a photo is present even though it's only referencing the original photo taken.
Is there a way to indicate which survey the original photos were taken in?
