index of the repeats in iteration
830
02-01-2023 06:21 PM
PamelaLandy
I want to place the repetition number and place it as a label at the beginning of each one, so that it can be known which repetition number is filling up, until reaching the maximum repetition number
repeat 1 : fill in info number 1
repeat 2 : fill in info number 2 ...
Katie_Clark
MVP Regular Contributor
I think the position(..) function should work for this. Use that in the calculate column for a hidden field, then reference that field in the label of the question you want to display.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
