Image capture method, change browse default location
1269
10-09-2023 02:03 PM
Halphen_Lucas
in Survey123 the bind::esri:style colum can be set for the image capture Method=browse
1. ¿how change or modify the location where the "browse" is pointing?  ¿Can it be set to point to a different location or specific folder or has to be in an On-line service?
2. If the Survey123 was created from an existing Feature Layer, and share the same "points layers" with QuickCapture.  I wonder ¿if photos taken with QC can be retreived form a Survey123 image question with the method set to "browse"?
abureaux
MVP Frequent Contributor
1. No. This cannot be changed. Would be nice though.
2. If I am understanding you correctly, I believe the answer is "yes". You would need to use the Inbox feature though.
abureaux
