If statement calculation, Survey123
46804
18
03-05-2018 10:57 AM
KatieWise
I am working on creating form with multiple repeats/questions.  What I am trying to do is calculate an answer to a question based on the which answer was chosen from the previous select_one question.  I will use sample data for simplicity sake.
select_one color: green, blue, red, yellow
calculation results based on color chosen (what I am trying): if(selected(${color}, 'red', 'Cardinal', if(selected(${color}, 'green', 'Parrot', if(selected(${color}, 'blue', 'Bluebird', if(selected(${color}, 'yellow', 'Finich', 'N/A'))))))))
I have received multiple different errors for trying this multiple ways, the current error is "requires 3 arguments, only provided 1"...Sometimes I get "requires 3 arguments, only provided 4 or 5 etc"
What am I doing incorrectly?
JamesTedrick
Esri Esteemed Contributor
Hi Michael,
Just to check, how does the evaluation work when 2 of the variables would report one classification but one variable reports another?  For example, TP = 18, TN = 380, CholoroA = 3.1(1 Oligotrophic and 2 Mesotrophic)?
For the most part, you calculation looks close to what your graph looks like; you shouldn't have commas in the evaluator section (for example, the first if should be ${P}<15 and ${TN}<400 and${ChloroA}<3 and I think your right-side parenthesis aren't lined up correctly - there should be 3 of them, one to close off each if() statement.
MichaelFazio2
Thank you, James. To be honest, I hadn't considered the values being in two different categories at once. I'll have to ask the user. As far as the statement, I'm trying a nested if statement now, but just having trouble with my brackets and/or parenthesis
GrzegorzIgnatowicz
Hey folks!
According to this topic I have a problem with setting condition to auto-fill next question:
In select-one question named 'Assignee' I have few choices like 'James', 'Jessica', 'Adam'... and I want to set condition for next question named 'Assignee_Mail' to show me i.e. if 'Assignee' is James, 'Assignee_Mail' should be filled as '[email protected]. This is very important for me because I want to use the question 'Assignee_Mail' field to set in Integromat as a dynamic value for e-mail recipient.
I tried few options for example...
if(selected(${Assignee}, 'James') or selected(${Assignee}, 'Jessica') or selected(${Assignee}, 'Adam'), ''[email protected]', ''[email protected]','[email protected]'))) but it doesn't work.
Could you help me please ?
Thank you in advance
G
by Anonymous User
Not applicable
Hi Grzegorz,
Yes it is possible to do what you want, but you need to use nested if statements, not one if statement with or expressions. It should look something like this:
if(selected(${Assignee}, 'James'), '[email protected]', if(selected(${Assignee}, 'Jessica'), '[email protected]', if(selected(${Assignee}, 'Adam'), '[email protected]', '')))
If that doesn't work, can you send a copy of your xslx file, and I can take a closer look and let you know the best way to do it.
Phil.
GrzegorzIgnatowicz
Philip Wilson‌ I can't find words to thank you! I've been struggling with this query for few days. It works now!
G
by Anonymous User
Not applicable
I have found this thread useful so far but there is a hang-up somewhere (calculation, type etc) that is not allowing my calculation to go through...
Context: I'd like to collect water temperature data in both Fahrenheit or Celsius but I would like the form to convert any Fahrenheit calculations to Celsius so I can have one column (hidden on the survey) on my output .csv spreadsheet. Currently, I have a decimal 'temp' variable, a select_one 'unit' variable with 'fahrenheit' and 'celsius' and now im hoping for a hidden integer field to calculate celsius based on the select_one 'unit' and decimal 'temp' fields.
decimaltempWater Temperature
select_one unitunitTemperature Unit
decimaltemp_cCelsius
My current calculation "works"t and updates with my survey123 connect preview, however I do not get the Celsius field to populate on my preview form (currently leaving the field visible to test systems but eventually want it hidden).
if(selected(${unit},'fahrenheit'),int((${temp}-32)*0.55555),if(selected(${unit},'celsius'),int(${temp}*1),'NA'))
if unit is Fahrenheit
then int(${temp}-32*0.55555
else if unit is Celsius
then int(${temp}*1
else NA
Does my current calculation reflect that?
If I want a decimal output in my hidden calculation what relevant columns should I be utilizing? bind: type? bind:esriFieldType?
JamesTedrick
Hi Clay,
Is there a third option, as you have nested the if statement to provide a value of 'NA' if neither Fahrenheit or Celsius is selected?  It does reflect what you describe, but doesn't make sense with the rest of your description.  If you want decimal output, 'NA' will not be a valid value.  You should set bind:Esri:fieldType to a floating point (Single/Double) field field type for decimal storage.
JessicaJThompson
Hello!  (Surveyt123 Connect | Version 3.14.274)
Thank you in advance for your assistance!!
I have an if/and calculation that creates a default value if 6 questions all have the same answer. However, one of the questions is relevant based on a previous response so it is is hidden on occasion, so it cannot be answered. This makes the if/and calculation void, even if all of the visible questions are have the same answer.
Is it possible to solve this with the calculation? Or do I have to rethink the workflow?
Thank you!
Jessica
ArchitSrivastava
Hello All,
I am stuck with kind of a similar problem.
We have an external CSV from where want to verify the entered code. If the entered code is correct then show the rest of the questions and if the value entered in code is correct we want to provide suggestion saying that entered code is incorrect but the survey doesn't seem to try and meet the condition. We have the following if  statement
We pull the code value from CSV in a field name (code) as hidden and use the following calculation
if(selected('${code}'='${enter_security_code}','${code_check}') and selected(${code}!='${enter_security_code}'),'${check_the_code}','${code_check}')
But this seems to error out a below:
It would be great if I can get any suggestions as to why this is not working. Any help would be highly appreciated.
-Archit
