I’ve just started playing around with survey123 by making various surveys with the web designer. Yet, whenever I try opening the surveys within Survey123 Connect I get versions of the following errors every time:
The XLSForm spreadsheet has been modified. Do you want to refresh the survey?
XLSForm with warnings: [row : 2] Question has no label: {u'type'; u'note', u'name': u'generated_note_surveyDescription', u'hint'; u'test 1'}
The errors start an endless loop and render Connect useless until I close the program.
I’ve uninstalled and reinstalled Connect and created very simple surveys with the Web designer (just one simple question) but the errors still occur.
-Todd
using Survey123 Connect for ArcGIS 2.5.44 for Windows 10
