I'm having trouble loading Survey123 on my Android tablet.
2105
02-23-2017 07:01 AM
BethanyCrenshaw
When I go to the Google Play Store to download the Survey123 app I get the error that my device is not compatible with the version of the app that is available.  I have updated my tablet to Android 5.0.2 and still get the same error.  My tablet is a Dell Venue 10.  Also, this tablet runs the Collector app just fine. Any suggestions would be tremendously appreciated.
JamesTedrick
Esri Esteemed Contributor
The Google Play store doesn't give reasons why a device is unsupported, only that it is.  I can confirm that it lists the Venue 10 as unsupported.
BethanyCrenshaw
Thank you James!  This is very helpful.  I will look into using a different device and try again in the future and see if an update will make that Dell tablet compatible.
MartinDe_Las_Heras
Hi, has this compatibility issue been resolved? Thanks!
JamesTedrick
The Venue 10 is now listed as a supported device with Survey123 3.0
MartinDe_Las_Heras
One of our users is having trouble downloading the application. Google Play says the device is incompatible. Using a Dell Venue 10 5050, Android Version 5.0.2
Will check again with user, not sure what the problem is.
Thanks!
