I have my Survey connected to the feature class through the pop up. The feature class is the point layer with every point having a unique ID. This ID should be pulled by a Survey to the form. And it is while I’m using the desktop application and the AGOL.
505
11-08-2017 03:38 AM
רחלייעקובסון
I have my Survey connected to the feature class through the pop up. The feature class is the point layer with every point having a unique ID. This ID should be pulled by a Survey to the form. And it is while I’m using the desktop application and the AGOL. However, on mobile device it doesn’t do it for some reason.
JamesTedrick
Esri Esteemed Contributor
Which application are you using on the mobile device?  What type of ID are you using?  We've seen some subtle differences with how GUIDs are formatted in mobile applications
רחלייעקובסון
Thanks for your reply. I have finally managed to deal with a survey. Seems like there was a problem with ID field. So adding a new one helped
