I get this error message "Editing is not possible because the objectId parameter was not provided." when I add a QAQC survey to an Ops Dashboard.
2394
06-15-2020 06:46 PM
Bryan_Wade
I created 2 surveys, one for initial submission and the second for reviewing the first. I created an Ops Dashboard to use for review purposes. When I embed the second survey in the dashboard I am getting the error message "Editing is not possible because the objectId parameter was not provided."  I created the surveys in Survey123 Connect but published them to the AGOL portion of my works enterprise. How do resolve the globalid/objectid issues that are occuring?
JoffreQUINTEROS_CARABALÍ
Hi Bryan, I solved it by placing the objectId
https://survey123.arcgis.com/share/3a9d7b9db3b4437fa9641d14b20a154a?mode=edit&objectId={objectid} , first put a number for example the first record with 1 and then change it to the field as variable and it worked for me
Cheers
