I cannot click on a point in Fieldmaps after creating it in Survey123
3258
14
06-29-2023 03:24 AM
EdHixson
Hi all
I am experimenting with Survey123 and creating some points on a web map. When I load this web map into Fieldmap with the survey123 points created for some reason I cannot click on any of them, which is a vital part of the survey123 process. I have had a look through the setting and I cannot figure out why I wouldnt be able to click on the points to view their attributes
Anyone has any advice or help it would be greatly appreciated!
All the best
-Ed
EdHixson
Hi there
Thank you for all the information, on the back of this message I have decided to open a ticket with ESRI
Thank you
-Ed
AndreasHall
Are pop-ups enabled for this specific layer? It is a setting in the web map.
Configure pop-ups (Map Viewer)—ArcGIS Online Help | Documentation
EdHixson
Hi there Andreas
Yes I believe I have that enabled correct, let me know
ATB
-Ed
AndreasHall
Is it in Field Maps or Survey123 you are trying to open the pop-ups?
EdHixson
Fieldmaps
AndreasHall
Have you tried updating the map in Field Maps?
EdHixson
Yes I have, I have duplicated the form, re-published etc. Nothing seems to allow me to press the points
AndreasHall
So the pop-up work in Map Viewer but not anymore when you open the map in Field Maps? I cannot figure out what could be the case for that behavior, sorry.
EdHixson
Yeah thats whats happening. Ah okay, no worries, thank you for trying
-Ed
ChristopherCounsell
MVP Frequent Contributor
Can you:
  • Share the XLSForm and more info on how the survey was published e.g. Connect version. This will help identify issues with your layer.
  • confirm the versions of Survey123 Connect, Survey123 field app and ArcGIS Field Maps?
  • Clarify if the behaviour occurs on multiple devices and platforms e.g. android, iOS
  • Add the Hosted Feature Layer to a new map. Enable pop-ups. Confirm it works in map viewer. Save the map, and see if the issue occurs in Field Maps.
  • If it does, capture logs in Field Maps, take screenshots/videos, and make sure you have a ticket with Esri support. They'll be able to work with you and take a direct look at your map (vs us, the public)
People have had this issue in the past and it's been tied to bugs (now fixed) or incompatibility. The latter there isn't much of anymore and was generally tied to map viewer classic vs new, or collector / field maps.
Hard to see issues if you are using a recent version of Survey123 and Field Maps, not doing any cutting-edge html/Arcade expressions, and don't have invalid design (e.g. reserved words or bad geometry).
