I can't get an image in the thubnail
699
05-17-2019 04:25 PM
by Anonymous User
Not applicable
I am working in Survey123 Connect and want to have a thumbnail image, but it just won't take it. I'm using a .png, just like in another survey I create, but in this one it just won't work. Why?
Thanks
by Anonymous User
Not applicable
Hi Sandy,
Is the file extension of the thumbnail in uppercase. ie PNG. If so this could be the cause, as we have a known limitation for this (discovered a few weeks back) and therefore the thumbnail name and extension must be all lowercase. For 3.4 documentation update, we have added the following Note to this section:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/styleyourform.htm#ESRI_SECTION1_F5D26BB2C...
Survey123 Connect requires all image files used for thumbnails to have a lowercase file extension. Uppercase file extensions are not recognized by Survey123 Connect, and these thumbnails won't be published with the survey.
If this doesn't resolve your issue, can you please send an example .png file that is not working so we can take a closer look.
Regards,
Phil.
