How to use an IF statement with a number range
1835
07-17-2020 12:49 AM
Mondi_GIS
Hello all
I have a calculation that i need to do where I ask field workers to measure the height of seedlings. I have created a decimal field where they input their height in cm's. In the next line i have a hidden field where I now want to calculate whether the seedlings are between 25-45cm. If the height falls inside this range, they should get a 0 value, and if they are outside they should get a value of 1. I have used this if statement, but it doesn't seem to return the rigt value. It seems just to give me a zero.
if(${q2_1_2_height}>=25, 0,(if(${q2_1_2_height} <=45, 0, 1)))
I have other criteria that are just Yes/No answers, where the yes gets a zero and No a 1. I then add them all up to get a Pass/Fail according to certain criteria. This is the reason why i want to convert the height values to a zero or 1 as well so that i can sum them with the other questions
Please could I get some help
DavidPike
MVP Notable Contributor
I'm no expert on this Arcade or 123 syntax btw.
though if it's on the basis of Condition, IfConditionTrueValue, ElseValue :
if (${q2_1_2_height} >= 25 and ${q2_1_2_height} <= 45, 0, 1)
Mondi_GIS
I just figured it out. I had to try several different ways, but this eventually worked for me
if(${q2_1_1_height} >=  0 and ${q2_1_1_height} < 25, 1, if(${q2_1_1_height} >=  25 and ${q2_1_1_height} <= 45, 0, 1))
Thanks for the help
DougBrowning
No need for two if statements.  The post above is correct.
