How to Update Address Location of Existing Survey123 Web Entry
101
Thursday
cjms
I am using a Survey123 form (version 3.25) created in the web and I have an Address question (configured with an ESRI world locator view). The Address and Geometry option is selected. When I initially submit a record, the address question works as expected:
  1. A suggestion appears
  2. I click it and the address question box populates
  3. Submit
  4. Confirm on the map that point is created at the address
However, if I try to go and edit a record (using the Data tab from the Survey123 website), then the location doesn't update.
  1. I type in a new address
  2. The suggestions will appear and I click one
  3. The text for the address updates
  4. Submit
  5. Check the map, but see the location is still the same even though the address field updated
Interestingly, if I switch to a Map question, then I can update a location. However, then I face the issue of extracting the address from the matched the question and it only returns the Place name for reason.
Is there a way to fix this without using Survey123 Connect?
