How to select only values less that 43?
693
08-07-2024 12:55 PM
JoseSanchez
Good afternoon
, concat('SequenceNo=', ${proposed_meter_sequence}, ' and ', ${proposed_meter_sequence}, '<=43' ))
I am looking for a way to select   proposed_meter_sequence values that are less than 43.  I tried the  syntax above but it does not work.
Please advise.
TonyContreras_Frisco_TX
The concat function is for text data, which cannot accurately be compared to numeric data. Is the proposed_meter_sequence column stored as integer or text?
JoseSanchez
Hi @TonyContreras_Frisco_TX
The proposed_meter_sequence column is stored as an integer.  In this case how do I only select values  <= 43?
Thanks
