How to prevent duplicates from being submitted in a free text field
1447
10-17-2023 01:22 PM
jochoa6
Hi. I'm trying to prevent submission when a duplicate value is entered into a free text field. I tried adding a constraint to the field with the instructions here: Add a unique constraint to a field—ArcGIS Online Help | Documentation
But I don't have the edit button on the unique field. Help please!
IsmaelChivite
Esri Notable Contributor
Hi. pulldata("@layer") may work for you.
Here is some background info: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-pulldata-quot-laye...
I attached an example below for clarity. To use the example:
  • Create a survey in Connect from the XLSForm
  • Publish the form
  • Once the form is published, replace the URL of the feature layer URL in K3 to target your own survey layer. Make sure the layer has query capabilities enabled
  • Publish again and submit
Hope it helps.
jochoa6
I'm getting the following error in the field. I'm not sure what I'm doing wrong. When I test out the survey the field that should be pulling the data is blank.
SyntaxError: Invalid regular expression flag 'n' in expression
Here is the code:
pulldata("@layer", "getValue", "attributes.free_text", "layerURL", concat("free_text ='",${free_text},"'"))
