How to prevent duplicate records before submission
347
03-24-2025 04:55 PM
ChrisJRoss13
I'm working on a Survey123 form and trying to configure it to prevent duplicate submissions based on the Business Name field. Ideally, I’d like the form to check whether a business name has already been submitted and, if so, display a message or prevent the user from proceeding.
I’ve come across a few references to using JavaScript functions in Survey123 for this type of validation, but I haven’t found a complete working example that fits my use case.
Here’s what I’m trying to do:
  • User enters a Business Name in a text field.
  • Before submitting, the form checks if that name already exists in feature layer.
  • If it does, the form:
    • shows an error message
JakeMatthys
Following this topic.  My organization also has use case to prevent duplicate submissions based on a key value.
TylerGraham2
I would look at putting a pulldata("@layer") function in the constraint field for Business name that queries the layer for the value someone is entering.  Here's a link to how pulldata("@layer") works and how to set it up. It would be simpler than writing JavaScript. The 2nd link does say that pulldata works in the constraint column.
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-pulldata-quot-laye...
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
