How to perform a search on a Web Map layer linked to a SURVEY123 survey?
596
11-22-2023 08:16 AM
AlexUreAl
I have a survey which is associated with a web map, this map has 2 layers, the first is the layer of the points that are created with each new record, the other layer is polygons that represent property plans. I would like to enable an option to be able to perform a geospatial search based on the plan number, so that it is easier for users to locate the property. Is it possible to do something like this in survey123?
DougBrowning
MVP Esteemed Contributor
AlexUreAl
Thank you very much for the post, it is really very interesting and I think I could get a lot of use out of it to extract information from my plane layer, I will definitely try to apply it.
However, there is something that I still don't know how I can solve, in AGOL I can search a layer by attributes, in this case I can search by plane number, when I enter the number and if there is a match, the map moves and is positioned on the property.
As shown in this image:
Now, what I need is to activate this same type of search on the map but from the Surver123 application, so that when I enter the map number the map is positioned over the property.
If you could help me with this question, I would appreciate it.
