Greetings,
Recently the data in a feature service for a published Survey123 Connect Form was deleted. After reimporting a previous save file of the data in the empty feature service, all of the creation dates were obviously changed to the date of the import of the old data. This leads to my problem, the data collected via this connect survey is assessed in the default Survey123 web dashboard (under the data tab). A crucial part of this review process is the filtering of old records by date (the records that were deleted and reimported into the feature service which now all have the same creation date). I thought I could get around this by creating new fields in the feature service for the original creation/edit dates but the default Survey123 web dashboard does not show the new fields I added as a work around. Is there a way to show these new fields, which are in the feature service, in the Surve123 web dashboard? Thanks!
