How to link to a Survey123 data page and specify the portal
616
02-15-2023 10:00 AM
RobBlash
I understand how to log into Survey123 with a specific portal as described in the help:
https://survey123.arcgis.com/?portalUrl=https://exampleportal.esri.com/arcgis
  But how do I link to a specific survey and specify the portal? For example, I want to hyperlink to a record like this
https://survey123.arcgis.com/surveys/MySurveyIDGoesHere/data?filter=(1.objectid%20is%202)&objectIds=2
When I add the portal parameter it doesn't work, I just land at the Survey123 site with AGOL login options, not my portal
https://survey123.arcgis.com/surveys/MySurveyIDGoesHere/data?filter=(1.objectid%20is%202)&objectIds=2?portalUrl=https://exampleportal.esri.com/arcgis
How do I adjust the link above so I'm prompted to log into my portal instead of AGOL?
RobBlash
I figured it out, I had a "?" that should have been an "&"  in front of the portal parameter
https://survey123.arcgis.com/surveys/MySurveyIDGoesHere/data?filter=(1.objectid%20is%202)&objectIds=2&portalUrl=https://exampleportal.esri.com/arcgis
RobBlash
