How to Increase Text Field Size without Losing Data
1753
02-26-2022 08:02 AM
Billy
We have a published survey that we need to increase a text field size. When we set the new size on the esri:fieldLength in Connect and then try to re-publish we get a warning that the data will be lost.
How can we increase the size of the text field without losing the data?
Survey123 Connect version: 3.14.256
Survey published to ArcGIS Online.
Regards.
JohannesLindner
I don't know how to do it in AGOL, but here's how you would do it in the Desktop environments, maybe it's similar...
  • create a temporary text field with at least the size of the original text field
  • copy all values from the text field to the temporary text field
  • recreate the text field with the new size
  • copy all values from the temporary text field to the recreated text field
  • delete the temporary text field
  • republish
Have a great day!
Johannes
shan_sarkar
In ArcGIS desktop you can simply increase the field length without having to create a temporary field.  The temporary field comes into play if you need to decrease the field size.
Refer Modify field properties
~Shan
JohannesLindner
Huh, seems like I wrongly remembered my struggles with changing field length... That's good to know, thanks for the tip!
Have a great day!
Johannes
DerrickWestoby
I don't think you remembered incorrectly, @JohannesLindner ...I think this behavior changed within the last year.
