Hi guys
i have created a form in survey123 which was successfully published and used to capture data. Ever since the form has changed for some reason and now re publishing the survey will cause all records to be deleted.
https://community.esri.com/t5/arcgis-survey123-blog/updating-field-types-in-existing-survey123-surveys/ba-p/898543
i have found this guidance, however i do NOT know which field is causing the problem.
How do i identify the field that has caused this? is there a way i can find the form that originally published the survey?
