How to get the name of a place given a location string xls form
595
02-09-2021 02:55 PM
AlejandroMadrigal
New Contributor II
HI!
When you calculate a location from a choice list, you get, at the data base, a string of coordinates, but not the name of the chosen place.
I cannot find an expression to simply get the name of the chosen location at the database results, without (for instance) repeating the question with another choice list.
Any sugestions?
Thanks a lot!!
BrettStokes
Hi Alejandro,
It sounds like you need to use the jr:choice-name() function to store the label of a selected item in your target feature layer instead of the name. Please take a look at the jr:choice-name section of the following blog for more details:
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-xlsform-functions-...
Hope this helps,
Brett
AlejandroMadrigal
New Contributor II
So grateful!
