how to Embed a website inside a survey
1381
04-05-2023 02:59 AM
RehanChaudhary
i have developed a multiple choice based quiz on survey123 connect and now i am managing it on the survey123 website. I want to be able to embed a website inside my survey so that when user choose the correct option, an iframe opens up beneath the correct answer showing more information in a website about the correct answer. is it possible to do this within survey123?
Richard_Purkis
Hi @RehanChaudhary
I believe the answer is to use a note question and the insert an iframe into the label. This is described in a previous post.
I must stress that this appears to be a workaround and is not a recommended workflow.
Hope this helps
RehanChaudhary
@Richard_Purkiswhen i try the above mentioned workaround and add the iframe in a label. it just shows me the complete iframe code and does not displays the website itself. Could you give me a hint as to what i might be doing wrong?
