How to download Survey123 Connect with a Portal for ArcGIS installation
1941
6
10-26-2017 01:54 PM
EricHeinrichs
I want to start using Survey123 in conjunction with Collector, but I cannot find a way to download the Survey123 Connect application without creating a separate ArcGIS Online account.
Is there a way to download and use Survey123 Connect, or will I have to create an AGOL account?
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Eric,
Can you try the account username you use to access my.esri.com?
EricHeinrichs
This is the pop-up that I get when I try and sign in with my my.esri.com Organization account.
JamesTedrick
Thanks Eric, I suspected that might be the case.  We'll work to address this issue.
AaronFraint
Has this issue been addressed? Through my job I have a Portal for ArcGIS publisher account, but am unable to log in with that account and download Survey123 Connect.
JamesTedrick
Hi Aaron,
We're working with the documentation team to update the download page; in the meantime you can access it via https://esri.box.com/v/Survey123Connect
ChrisRoberts2
Hey James
Any progress on this? I see there is a more recent version available.
