How to download all the photos only of the selected surveys and not all surveys.
1481
6
01-11-2019 08:53 AM
ChristopherVan_de_Wyngard
When a record is selected I have tried to do a File Geodatabase export and it downloads all the records not just one or two being selected.
BrandonArmstrong
Hi Christopher,
Are you using the method highlighted in the screenshot below?  I just tested by selecting once record and exporting, which worked as expected.
Brandon,
I verified that I was using the method as highlighted in the screenshot and when I download a File Geodatabase it downloads all the images from all records.
My method is to make sure that the “Selected records only” is selected, that only one record is selected, and then I click download “File Geodatabase”. Then I run the ArcMap script to get photos and it pulls all the photos for all records.
Chris
BrandonArmstrong
So, when you add the feature class from the exported file geodatabase to ArcMap, records other than those that were selected are present?  Which ArcMap script are you referring too?
Brandon
The script that I am currently using is the one recommended by survey123, the arcpy code is below. When I use ArcMap to pull the images from the geodatabase then I still pull all the images from all the records and not just the one selected originally.
import arcpy
from arcpy import da
import os
inTable = arcpy.GetParameterAsText(0)
fileLocation = arcpy.GetParameterAsText(1)
with da.SearchCursor(inTable, ) as cursor:
for item in cursor:
attachment = item[0]
filenum = "ATT" + str(item[2]) + "_"
filename = filenum + str(item[1])
open(fileLocation + os.sep + filename, 'wb').write(attachment.tobytes())
del item
del filenum
del filename
del attachment
BrandonArmstrong
Thank you for clarifying, Chris.
As it turns out, the selection of records on the parent layer in the Survey123 website does not currently correspond to the the related table storing the attachments. This is why the exported related table contains all attachments within the related table.
We do have an open issue for this functionality and we are looking to include it in a future release of the Survey123 website. I have added your comments to the issue and will update you when this changes.
Best,
Brandon
Thanks Brandon,
I look forward for the future release of the Survey123.
Thanks for your time,
Chris
