How to display two fields using join
1150
12-16-2023 04:48 PM
CamKenny2
I have two questions in a repeat:
Species and PercentCover
Because these are in the repeat, I am using the join to create a running list of the species entered in the repeat.
I have been successful at doing 1 field using join('<br>', ${Species}) outside of the repeat, but I'd also like to display the Percent Cover as well something like this
join('<br>', ${Species},' - ',${PercentCover})
I know this doesn't work.
I tried the concat outside of the repeat and it too works, but only for the current repeat and doesn't keep a running list like join does.
If anyone can help out that would be awesome.
abureaux
MVP Frequent Contributor
You need to concat() the two fields inside the repeat. Then display outside.
abureaux
