How to delete web form (but keep field app form) AFTER publish
1515
07-02-2024 10:10 PM
ChristopherCounsell
MVP Frequent Contributor
When publishing a survey you get an option to disable the creation of a web form. Accessing the web form gives you this screen:
Is it possible to delete the webform for surveys that have been published already?
Do you just delete the .webform file from the Survey123 Connect contents folder then republish the survey?
ChristopherCounsell
I published then deleted the .webform file in Connect and the option to create a webform came back when re-publishing from Survey123 Connect. I turned it off and republished (no .webform) but the survey was still able to be launched in the browser.
It doesn't look like it's possible nor an intended workflow. I'm not fussed enough around it to create an ArcGIS Idea
abureaux
Honestly not sure. But this has been on my mind for a while, so curious to the correct answer.
ChristopherCounsell
