how to automatically download survey records
1969
08-21-2019 08:27 AM
CUARTA_OPORTUNIDADLOCAL
I have an enterprise license, and to facilitate my procedures I want to automatically download the records found in my surveys in order to send the reports to the people who fill them out.
I want to know why method I can schedule the download of these files taking into account the entity report template
ChelseaRozek
MVP Regular Contributor
The easiest method is to use Integromat to create a webhook that will automatically generate a report and send it to an email of your choosing. We gather the email as a question in the survey, which Integromat can access.
More information:
Webhooks—Survey123 for ArcGIS | ArcGIS
Survey123 Integrations | Integromat
MarisaClaggett
Hi Liliana,
Have you looked into using the ArcGIS Python api?  You can create a script using the api to get the item id of your survey, download the data to other formats, and generate reports.  After creating your script, you can run at scheduled times.  Let me know if this helps!
arcgis.apps.survey123 module — arcgis 1.6.2 documentation
Marisa
In this API there is any form that send those records automatic in a email?
EmmaHatcher
Hi Marisa,
I'm trying to export a survey to a file geodatabase and am running into problems with the export_format strings. The documentation doesn't have much in terms of what the strings actually need to be.  I tried using "File Geodatabase" as my export format, and I get the error below:arcgis API for Python survey123.Survey.download type error showing unexpected format for export_format argument
Here is the code that generated that error:
import arcgis
from arcgis.gis import GIS
from arcgis.apps.survey123 import Survey, SurveyManager
import os
gis = GIS("https://adfg.maps.arcgis.com", 'username', 'password')
tbl_path = r"C:\Data\SurveyDownload_" + str(today).replace("-","_")
if not os.path.exists(tbl_path):
    os.mkdir(tbl_path)
sm = SurveyManager(gis)
survey = Survey(survey123_form, sm)
survey123_form = gis.content.get("2ea1bdb67eda442eac567b15edd1181a6")
survey123_form.download(export_format = "File Geodatabase",
                        save_folder = os.path.join(tbl_path))‍‍‍‍‍‍‍‍‍
