How to add two or more relevant to select_multiple question?
3596
08-19-2021 07:40 PM
anonymous55
Hello all,
I used "or" to add another relevant to multiple question from select one question. However, I am not sure if this is correct solution or I need to used "selected" option.
What is different between or and selected?
select_one parking_location
parking_location
Parking Location
select_multiple corral_maintenance
corral_maintenance
What is the state of the parking corral?
Select all that apply.
${parking_location}='sidewalk corral' or ${parking_location}='roadbed corral'
select_multiple corral_vehicles
corral_vehicles
How many other vehicles are in the corral?
DougBrowning
MVP Esteemed Contributor
Looks ok to me.  My guess is you are checking the label value and not the name value in your parking_locaiton list.
Other idea is I have seen weird errors when you use the same name for the list as the field.  I usually add the word List to the end to be safe.
selected is just something you can use instead of =.  Mostly used for select multiple since = would not work.  Your or looks ok.
Hope that is it
IsmaelChivite
Esri Notable Contributor
Hi. The selected() function is your friend here. Check the Common mistakes, errors and other tips section in https://community.esri.com/t5/arcgis-survey123-blog/understanding-multiple-choice-questions-in/ba-p/...
The expressions you are currently using will only work if the user selects only one choice from the select_multiple question.
DougBrowning
${parking_location} is a select _one though so this should work.
anonymous55
I tested with OR and it is working. interesting i couldn't find any articles about this and all videos just show one relevant  option not multi ones like my issue .
DougBrowning
Can you just post the form way easier to troubleshoot.
