Im trying to make an http request , using the example :
function decodeVIN (VIN){
// Output value. Initially set to an empty string (XLSForm null)
let outValue = "";
// Check the length to make sure a full VIN is provided
if (VIN.length<11){
return outValue;
// Add the VIN to the decode VIN API request
let url = `https://vpic.nhtsa.dot.gov/api/vehicles/decodevinvalues/${VIN}?format=json`;
// Create the request object
let xhr = new XMLHttpRequest();
// Make the request. Note the 3rd parameter, which makes this a synchronous request
xhr.open("GET", url, false);
xhr.send();
if (xhr.status !== 200) {
} else {
outValue = xhr.responseText;
return outValue;
But my i want to make an request that send an binary file in pdf end wait for a response. Anyone know how to do that?
Hello @Alex_matias,
Custom JavaScript functions in Survey123 don't support asynchronous calls nor does it support accessing local files.
To send a file and wait for a response, you can use a tool or script that supports asynchronous operations. For example, in Python, you could use the library to send the file and then wait for the response business. Ensure that your server or service handling the request is set up to handle file uploads and provide a response.
