How do I watch console logs in PRD Survey123 App
1221
03-12-2018 12:03 PM
TL2
I would like to watch them live while I submit a survey.  I know I can do this in the AppStudio console but am not sure how with a deployed app.
BrandonArmstrong
Hello,
If you are looking to observe the console output while submitting a survey using the Survey123 field app on the same computer that you have AppStudio installed, you can do so by opening the Survey123 field app > select top right menu > Settings > Diagnostics.
If you are looking to observe the output when submitting a survey using the field app on a mobile device (iOS, Android), you can reference the documentation provided below...
Capture console output—AppStudio for ArcGIS | ArcGIS
Hope this helps,
Brandon
