How can you change the "theme" in connect
5027
7
02-28-2018 09:36 AM
SamuelRoss
IN the online survey builder you can change the theme to change the background colour to a different colour or image. How can I do that with a survey made in the desktop builder?
Thanks
JamesTedrick
Esri Esteemed Contributor
In Survey123 Connect, you can set theme settings via the 'Style' tab when a form is being previewed.  See Style your survey—Survey123 for ArcGIS | ArcGIS  for more information.
SamuelRoss
I want to get rid of the green background. how do I do that? when i changed the background colour in the style section I just got that blue. What if I want the rest of the green to go?
MatthewMcBurney
Like Casius has mentioned, It's the "wrapper" outside of the form that we would like to configure\change from the pale green. This doesn't seem possible from the Survey123 Connect application. Is there another way? It seems to me that a previous release did not have this configuration.
SamuelRoss
Just wanting to push this discussion back up as it has not been solved yet
ChelseaRozek
MVP Regular Contributor
Would love to be able to change that color, anyone figure it out?
joerodmey
I am looking to do the same
by Anonymous User
Not applicable
